Hi, I have backed up(?) several DVDs, and i use DVD Shrink to do this, and DVD 43. I have a weird problem, i have two movies that are backups themselves, and will play fine on my DVD player, but when i put them into my PC or laptop, they wont work. The laptop locks up, and the PC just tells me there is no disk in the drive. Any ideas??? I did not make the backups by the way, but dont understand why they wont play????
MM.
"....thats not a tool, thats a damn BRICK!"
Results 1 to 9 of 9
Thanks Man, but i kinda figured that, but i have other movies on the same media, and they work fine!!!
MM
"...are yo driving with you eyes open?..or just like using the force??" -
It may be a wild coincidence, but maybe the drives are going bad.
Also, just to be sure, do a dvdinfo scan on the discs to be positive if they're bad or not. -
OK i am asking this to baldrick, might sound stupid but what does CROSS POST mean. If i means putting the same thing in two forums, then i am sorry, but i didnt know which one to use!
MM -
Thanks for the reply, but my desktop drive is brand new, and works fine with other discs, and my laptop is only year old. ???
help
MM -
I have had the odd dvd that is not recognised by my reader & burner on my pc, though they play ok on my dvd player. The way I got around it was to start up dvddecrypter http://www.dvddecrypter.com/index.php?act=download , click on Mode/File F, select your player or burner. Dvddecrypter recognised the disc straightaway. You could then copy the files & burn another copy. The funny thing is that if I then shut down dvddecryter & started up my pc player ( WinDVD ) it would then play the dvd. Try it, it works for me.
It may not be a problem with the media type your using. You may have two bad disc. I would try burning them again.
hey bidefordboy, i have not had a chance to try yet but i will this afternoon, thx for the tip, i will let you know how it turns out
MM
Dvd Backup
By DIKYDO in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 09:30 -
DVD Backup
By sixleaf in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2009, 01:50 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 16:55 -
Help with DVD Backup
By zeroplace in forum DVD RippingReplies: 3Last Post: 23rd Jun 2008, 10:48 -
DVD Backup
By romanstopme in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 09:38
