I've download The "Kill Bill vol. 2" dvd and I replaced the korean subtitles with Hebrew subtiltles(with no problem).
My only problem is to replace the "subtitles menu" (I wanna keep the rest menu) with one new the I created(with Heb instead of Korean).
Results 1 to 9 of 9
dvdremake pro. i hope you downloaded kill bill vol2 from your original dvd...or else buy it.
I tried with DVDremake(replace that menu with one that I create,export & import buttons) but the menu of the dvd created corrupt.
I need another application or guide please.
P.S:
Baldrick dont worry I bought the original Dvd in Israel but its suck(menu,extras).
So I download the USA version. -
OK, I guess you are not using the latest version so it's pointless trying to help you with that version. You need to get version 2.6.6 as 2.2 is very old and is a very well known version to most people in DVD forums
I tried with the new version and the problem now is that the new subtitles menu craeted without the buttons (even that i export the buttons from the original menu & import on the new).
it won't work as the subpicture probably won't be the same so the highlights won't work for the buttons
VobBlanker substituir o menu/How to replace DVD menus with VobBlanker
By escarlate in forum Authoring (DVD)Replies: 24Last Post: 31st May 2011, 01:52 -
How To Create A functional button and replace the DVD menu using free tools
By escarlate in forum User guidesReplies: 4Last Post: 31st May 2011, 01:44 -
VobBlanker: Replace menu in multiangle cell?
By kpic in forum Authoring (DVD)Replies: 0Last Post: 7th Jun 2010, 18:02 -
Edit & Replace DVD menu with PGCEDIT?
By kpic in forum Authoring (DVD)Replies: 1Last Post: 27th May 2010, 16:40 -
Replace subtitles lines
By traucostar in forum SubtitleReplies: 2Last Post: 1st May 2008, 20:56
