Hello
I'm running AVer Media DVD EZMaker USB2.0 digital video maker.
It captures both video and audio into an Mpeg2 which works well.
Problem is the audio is captured fraction of a second ahead of the video, throwing the two out of sync. Is there any adjustment that can be made.
I'm running an Athlon XP3200 (2.20GHz) and 1.0 GB Kingston 400FSB RAM. Disappointing results. Thanks Mike
PS this is comming from a dv or hi8 output. In either case once the capture is on HDD, the delayed video shows. TomTucker: "only slightly-only slightly"
You need a Timebase Corrector between the source and your USB capture box's analog inputs
All the info I see points to it being a video signal-oriented clean-up device. No audio inputs...Am I looking at the right thing?
not at this point. The hardware/application captures from source and renders Mpeg2. Which when viewed from hard drive, is slightly out of sync. I'll ck the link. I may be dealing with a USB1 on the motherboard instead of USB2.0...just more money...
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
How to sync video with audio
By Denster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Apr 2010, 22:25 -
Best way to sync audio/video for part of a video
By marioval in forum EditingReplies: 2Last Post: 19th Mar 2010, 13:30
