Hello...
I have an athlon 1800XP 256ram.
I recently got a new DVD recorder (NEC ND3520). Everything works fine except DVD ripping.
To rip a 6-8GB original DVD with DVD decrypter it takes 16-20 minutes, sometimes even more. Is that normal?
A friend of mine says that it should take 5-10 minutes. For already ripped 4.7GB DVD-R/+R's it takes about 5-6minutes.
I have installed the latest modified firmware that enables bitsetting and disables riplock, shouldn't that fix the problem? Is there something i can do or is that how long it's supposed to take?
Results 1 to 9 of 9
Most of us find that this drive is really slow even with the riplock removed. What you are experiencing sonds about right depending on the disc. I would recommend either the AOpen 1648 AAP or the Liteon 167T with codeguy's firmware.
Still a few bugs in the system... -
yea, i heard that hacked firmware helps u rip faster with that drive, AOpen, yuck, i have heard more negative about that drive then all other drives put toghter
also the 1673 liteone is good
my 1633 CF to 1653 cstj rips pretty fast, but i dont care how long it take lol, i use dvd shrink tho, so i rip and encode to the right size same time, usally takes 9-15 minutes for the whole thingmaybe i lucky
Originally Posted by koolaidwaStill a few bugs in the system...
While those rip times don't sound too bad in my opinion, have you looked to see if the unit you are ripping from is in PIO or DMA mode?
If possible set to DMA mode and see if that speeds things up any.
Sabrowww.sabronet.com - It's all you need...to know -
Ripping speed for dvd-r
By vcd4me in forum DVD RippingReplies: 10Last Post: 22nd Apr 2011, 05:45 -
PROBLEM RIPPING DVD+RWs FROM LG DVD RECORDER
By i am x in forum DVD RippingReplies: 11Last Post: 27th Aug 2010, 17:39 -
DVD Fab v/s AnyDVD Ripping Speed
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 25th Mar 2010, 13:04 -
Problem ripping standalone DVD recorder disc
By mojo in forum DVD RippingReplies: 22Last Post: 28th Oct 2008, 23:33 -
converting to AVI or mp4 with stand alond dvd recorder..speed test
By diablo_ogre in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2008, 09:55
