I am just starting out. I have several files that I capped with my pc to .avi or .mpeg format. I want to convert them and then burn them to dvd+r. From checking some of the other dvdr's I have, I think I need to convert them to vob files and then burn them. I have cucusofts pro converter and their dvd author. When I use the converter I have to select NTSC or PAL. My question is, if I chose NTSC will that make my dvd'rs region 1? Or will they be able to be played in any region? I am sending copies of these to family in th UK so they have to be able to watch them as well. IS there a way or program that will burn or convert them to be region free?
Region has Nothing to do with "Pal" or "NTSC" It will burn them Region Free.
Region Coding
Region coding is how Hollywood studios stagger DVD movie releases across the planet. These codes ensure that one country doesn't get a DVD movie before the same movie is out in that country's theatres. In their corporate omniscience, movie studios have carved the planet into regions with each region having a specific code.
All DVD players and discs have region codes. A DVD player and disc must be of the same region or the disc will not play.
If you want to watch movies from other countries, you need a multiregion DVD player. This will allow you to play any disc from any region. However, because TV standards differ, you might need a specialized NTSC/SECAM/PAL TV or a DVD player that can output any signal to the standard your TV accepts. TechTV -
PAL
Short for Phase Alternating Line, the dominant television standard in Europe. The United States uses a different standard, NTSC. PAL delivers 625 lines at 50 fields (half-frames interlaced) per second. The resolution of a PAL VCD is 352x288 pixels, a PAL SVCD is 480x576, and a PAL full D1 DVD is 704 or 720 x 576. -
Thank You. I wasn't sure. I have always done vcd's and am just starting with dvdr's. I wasn't sure if it worked the same.
Ntsc BluRay players play PAL(region-free) dvdr?
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Nov 2009, 19:48 -
Program Philips DVD Recorder DVDR 3575H/37 to be Region Free
By hyades in forum DVD & Blu-ray RecordersReplies: 1Last Post: 21st Dec 2008, 13:18 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16 -
Philips DVDR 3577H region free hack?
By madsrunner in forum DVD & Blu-ray PlayersReplies: 6Last Post: 22nd Apr 2008, 06:23 -
DVD Recorder Philips DVDR 3475/37. Help-me with region free.
By Aurelio in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Sep 2007, 14:04
