Results 1 to 19 of 19
    I don't think this would be considered warez but I was wondering if anyone here on the forum, maybe close to Ohio, has the executable of sp1 saved or archived and would be willing to put on cd and mail to me?
    I want to use my copy of xp pro to make a slipstream of xp pro w/sp1 and then one with sp2.
    Or can anyone tell me the big difference between sp1 and sp1a.
    Thanks if anyone is willing to send me sp1.
    Fun in the sun, Oh no my friend, Fun on the sun!
  2. Member SquirrelDip's Avatar
    Nov 2002
    I thought SP2 covers all of SP1 - can anyone else confirm?
  3. Why now just download it?
  4. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    you can get one for free from microsoft
    http://www.microsoft.com/windowsxp/downloads/updates/sp2/cdorder/en_us/default.mspx
    you might also check with local businesses (best buy, circuit city, office depot, etc).. they may have the discs in their stores for free
  5. Banned
    Sep 2004
    Inner Circle of Thought
    Yes,
    SP2 covers SP1.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    sp1 is on the ms web site -- anyway , its right here
    http://www.microsoft.com/windowsxp/downloads/updates/sp1/network.mspx
    Thanks for the reply all! As in regards to downloading it, there is no link to sp1 anymore, just sp1a and sp2! I am not ready to try sp2 yet as for compatibility issues and problems I have read from other post's and forums and customers complaining to me where I work.
  8. Member waheed's Avatar
    Jul 2003
    Manchester, UK
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    did you read the post i did above ?
    look on the right and hit the word "GO"
  10. Член BJ_M's Avatar
    Jul 2002
    Canada
    here -- see the word go on the right:
  11. Член BJ_M's Avatar
    Jul 2002
    Canada
    oh -- the reason sp1 is not available is that it had a big bug in it:
    Microsoft has acknowledged and patched a glitch with its Windows XP Service Pack 1 update that can cause system slowdowns, but has not yet made its still-developing fix widely available.
    Because of changes made in SP1 to Windows XP's memory management system, programs that affect large blocks of memory may take up to ten times longer to load on a system running SP1 than on one without, Microsoft said.
    The company detailed the problem on its support Web site in a recently posted Knowledge Base article, "Programs Run Slower After You Install Windows XP SP-1" (article #815411).
    Bugs and Fixes
    The bug affects both the Professional and Home Edition versions of Windows XP. Released in September, SP1 includes fixes for a number of security flaws and bugs discovered since Windows XP's debut.
    For now, the only official way to obtain Microsoft's fix is to contact the company's Product Support Services department.
    Although Microsoft charges customers for some support calls, customers requesting this patch will not be charged, according to a company spokesperson.
    Because the problem is rare, Microsoft has chosen not to offer the patch for download on its support site, the spokesperson said.
    Unless users are severely affected by the problem, Microsoft recommends that they wait for a broad release of the SP patch or until the next Windows XP service pack is released.
  12. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Bugs and Fixes
    Thats what i also though. The link i provided does not work either.
  13. Banned
    Sep 2004
    Edit
    Ok, thanks anyway guys, I guess I will just go with sp1a.
  15. Banned
    Sep 2004
    The SP1A has the virtual machine removed. You will need to visit Sun's website to download the java runtime program.
  16. Член BJ_M's Avatar
    Jul 2002
    Canada
    and thats not a bad thing
    MS never really got a grip on Java as they were always trying to kill it (same with openGL)
  17. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    I live in Ohio, but I don't have SP1 or anyother update for that matter.
  18. Член BJ_M's Avatar
    Jul 2002
    Canada
    did you get a computer yet or still surfing on your 'speak-n-spell" ?
    Thanks guy's for the replies! I ended up using sp1a and just used it on a computer I got for free. Well almost free, I had to install operating system on friends new hard drive and he gave me a computer that was sitting in the garage. He said it would not boot up so I took it home, turned it on and all it did was sit at the windows ME screen. So I used my freshly slipstreamed sp1a xp pro and it booted up no problem. Been runnin for almost a week now. Man is he a dummy! Just Kidding, He is cool! But he is the type that will just buy a new one and not even try and fix the one that went bad. Now the wife is mad that I got 3 computers! Anyway thanks to all for the replies!
