Hi I have a few questions about working with Sony's DVD Architect.
1. Once I prepare and burn a DVD the software renders all my video (I gave it AVI's in the first place). This process takes about 5-6 hours and half the time I'm returned with an error message and my disc hasn't burned. If I try to burn again it wants to rerender everything and take another 5-6 hours. Trial and error like this at 5-6 hours a pop is a real pain.
Is there anyway to save the video that DVD-A has already rendered so I can try burning again in a shorter period of time?
2. When creating menu's is there any easy way to copy and paste a design I make from one menu to the next.
For instance I created a scene selection menu and wanted to change the look from the default. So I changed the first page but then had to change each other page to look the same manually. I'm looking to a quick way to change them all.
Thanks.
1. When you go to MAKE DVD choose prepare and make the DVD to the hard drive. From the resultant VIDEO_TS built on the hard drive you can burn any # of copies and your project will not need re-compiling ever.
2. Create the menu outside ARCHITECT as a .BMP .TIF or .JPG (uncompressed) at 720x480 and just import this background repeatedly when creating -
Another thing on DVD-Architect...
If you want to avoid encoding within the authoring program, do it before you get to that step.
I am assuming you also have Vegas? I do my editing (commercial deletion, etc.) there, then encode the AVI using the built in DVD Architect template (MPEG2). Then go back and render the audio in AC-3. With DVD-A you need to have a separate audio and a separate video file, doing it this way will give you compliant files that need no re-encoding. When I am ready to "Make DVD" in DVD-A, that process takes no longer than 15-20 minutes, depending on how many motion menus I have b/c it isn't doing any encoding, other than the menus.
DCSOS is correct, make the DVD on your HD and you can use Nero or whatever to burn the DVD over and over.
I have done it this way for many, many DVD's and they all turned out great. I am a big fan of DVD Architect as you can probably tell...
DVD Architect 5.0
By Mr. Robinson in forum Authoring (DVD)Replies: 1Last Post: 4th Nov 2009, 10:59 -
DVD Architect Subtitle Questions (Problem solved)
By NoBuddy in forum SubtitleReplies: 9Last Post: 4th Jun 2008, 08:30 -
DVD architect
By romanstopme in forum Newbie / General discussionsReplies: 4Last Post: 7th Apr 2008, 00:57 -
DVD Architect help
By monks19 in forum Authoring (DVD)Replies: 11Last Post: 23rd Aug 2007, 06:46 -
DVD architect
By Abiyad in forum EditingReplies: 1Last Post: 19th May 2007, 08:02
