Hello,
As a newbie, I have a question:
Is is possible within ffmpegX to run a decoding session only for e.g. the first 3-5 minutes of a movie and have all the authoring/post-processing done? This would help testing our different settings without having to go through a full movie conversion, which takes hours. I am having troubles understanding how to work out aspect ratio conversions when converting a divx to DVD, and there is nothing more annoying than finding out that the image is stretched after an several hours wait. I have read the following guide: https://www.videohelp.com/forum/userguides/174200.php , but still it is not always clear if I am doing everything correctly.
If not, is there a tool that would cut out a few minutes of a movie, in order to make a sample?
Thanks in advance for any help and advice.
Regards
Can't you cut a 3-5 min segment out of (a copy of) your source movie? ffmpegX can split avis, or use Explicit.
Premiere and sample rates
By tpapictures in forum EditingReplies: 6Last Post: 4th Apr 2011, 20:05 -
white balance-sample
By kzeko in forum RestorationReplies: 20Last Post: 22nd Oct 2009, 19:06 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
Where can I find 720p50 sample?
By johdeck in forum DVB / IPTVReplies: 2Last Post: 27th Nov 2007, 20:45 -
NeroVision 3 Sample format?
By LiBiDoXP in forum Video ConversionReplies: 0Last Post: 1st Jul 2007, 12:50
