Hi guys,
Need help with VirtualDub! I deleted my old VirtualDub, and Installed the new one, But when I tryed to capture, I went to the compression area and I only see like 4 Different Compression codecs! I use to have a ton of different ones! What do I need to do To get Most of them back? Thanks for the Help!!
Take a look to the left under "Tools | Codecs" you can also find several at http://www.doom9.org
Guest
Hi,
I am new to Virtual Dub but exactly the same thing happened to me. I re-installed VD and
now it does not recognise my codecs (which are still installed). Can someone tell me how
to get VD to re-examine my system for installed codecs - or is there some other problem.
(I have re-installed codecs - operating system everything.... new capture drivers...
thanks
O
VirtualDub Compression Not Working
By jjis in forum EditingReplies: 3Last Post: 3rd Apr 2011, 10:14 -
different compression virtualdub
By chewie8008 in forum EditingReplies: 14Last Post: 8th Aug 2009, 13:45 -
Virtualdub compression
By quxote in forum Newbie / General discussionsReplies: 25Last Post: 26th Jul 2009, 08:59 -
Threaded Compression In VirtualDub
By Soopafresh in forum Latest Video NewsReplies: 14Last Post: 1st Feb 2009, 03:15 -
Audio compression with VirtualDUb!
By kehn in forum AudioReplies: 5Last Post: 27th Jul 2007, 01:10
