My friend gave me a mpeg file which he converted from his ATI .vcr format to SVCD mpeg2 (using tools provided by ATI). The mpeg file play ok on his computer (winXP) using WMP 9. But I have problem playing it on my PC running WIN2000 WMP9.
At first WMP said it encountered an error while opening the file. The error flash quickly on the screen and disappeared. But I think that it was trying to download a codec.
I downloaded and installed "mpeg-2_codec[www.free-codecs.com].zip". Now WMP plays the audio and not the Video (blank screen)
Any help ?
I prefer to play it with WMP and not installing another software player.
The issue isn't JUST a codec, but rather convincing WMP that it's an MPEG2 file at all. Is the file extension .MPG? That kicked my butt for a while. Some codecs seem to have the ability to tell built in, and some don't. You might need to change the extension. I know it sounds silly, but that's the way it is.
Or... you could install PowerDVD, which puts its own MPEG2 codec into the system.
The problem, of course, is that no matter WHAT the aspect ratio will be all wrong. SVCD's are 480x480 and that's supposed to be 4:3, which of course it won't be. So unless there's some amazing new codec which auto-upscales the horizontal resolution by a third, you're stuck using some other player ANYWAY, since WMP won't let you skew the video in just one dimension.
How the make wmp automaticly play?
By obsh in forum Video Streaming DownloadingReplies: 0Last Post: 6th Sep 2011, 04:14 -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
Can't play HD content on Win7 + WMP 12
By Zippy1970 in forum Software PlayingReplies: 0Last Post: 30th Sep 2010, 19:42 -
Cannot Play DVD in WMP/VMCE
By nukmed in forum Software PlayingReplies: 3Last Post: 7th Oct 2008, 14:50 -
DVD to something Quicktime and WMP can play
By Hardway in forum DVD RippingReplies: 2Last Post: 13th Aug 2008, 14:22
