hey
ok i just got the emerson vcr/dvd recorder combo... and right on the box it says.. DVD-R's only... so in the same store i bought a bundle of dvd-r's
when i insert teh dvd into teh drive.. it says that there is nothing on the dvd.. which makes sense.. but when i try to record... it says that it can't write to this dvd because the format is invalid...
the make of the dvd's is TDK. now is there a difference between dvd-r's???
one more thing that the manual says is that under teh dvd-r its got a small R4.7 what does that mean?? are there different kinds of dvd-rs ???
any info would be greatly appreciated
Are you sure the combo is dvd RECORDER .. and not just PLAYER ?
• Records onto DVD-R / DVD-RW
I checked the specs and it does record on that format,maybe it doesnt like that brand of dvd-r,try another brand such as maxell dvd-r made in japan.I think,therefore i am a hamster. -
I know this is a tad late, but I'm adding this reply so people who buy this unit can actually find the information here if need be.
You need to upgrade the firmware on the unit. I had the same problem, and then upgraded. Problem now gone. Visit the official Emerson site (link has firmware upgrade at bottom):
http://www.emersonelectronics.ca/index/screen/products_3/model_ID/1845.html
Hope this helps.
Lay-er,
Z. -
Does anyone know where to get a current firmware update? This thing won't read any dvd's to record. It's ridiculous and their website isn't up anymore. Please help!!!!!!!!
I tried that address - are ther any updates on the EDVR95E? Is it true that the unit will not support TDK or is there firmware available elsewhere?
DVD player doesn't recognize XVID files
By Theodorist in forum DVD & Blu-ray PlayersReplies: 11Last Post: 17th Jan 2010, 23:42 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 06:16 -
Suddenly, burner doesn't recognize blank DVD
By slats7 in forum ComputerReplies: 9Last Post: 13th May 2008, 11:10 -
PSP doesn't recognize format
By rqthrottle2 in forum ffmpegX general discussionReplies: 5Last Post: 6th Jan 2008, 13:32 -
Ulead DVD MovieFactory 6 - Doesn't recognize DVD
By urlilgurl017 in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2007, 12:52
