Hi, I have NEC ND-2500a Burner, Ritek Dvd-r 4x discs, Nero 6 full version
I want to convert my divx movie into dvd. So i used the winavi converter. everything went fine and it created a folder, about 3gb in size. Then i went to nero 6 burning rom, and burned a dvd video disk. However when I play it on my dvd player, there is slight delay of one fifth of a second throughout the movie. It is really unwatchable and annoying. There were a couple dvd's i made and they were perfect, however most have this delay of play problem. I will greatly appreciate if someone can help me out. Thanks
Results 1 to 10 of 10
Do you mean the audio and video are out of sync? This happens when the AVI file is encoded with a variable bit rate (VBR) instead of a constant bit rate (CBR). You will need to use a program such as tmpgenc and process audio and video seperately. There are many guides on this site to tell you how to do that.
In the future, I would suggest that before you burn the DVD, that you play back from the hard drive first to see if there is a problem. Or, burn it to a DVD-RW. That way you can avoid wasting a
DVD-R.TANSTAAFL -
no, the audio and video are in sync. Its just that when I play it back on dvd player, there is delay in playback, it sort of looks like moving images when i think about it, but not really that slow, its like one tenth of second delay constantly. Its similar to when you try to play a high end game on slow computer, and it will run slowly like moving images. Before I burned i plyed the dvd folder in powweer dvd, everything is perfect, this only occurs after i burn any video on dvd-r disc.
I have tried it again and there is constant delay in playback. created video ts folder plays fine when i choose play dvd from hd. any other suggestions, help a brother out
Have you tried it on another player? Have you tried playing in your computer from the DVD? Also, you may want to try another media as well. Could be your player just doesn't like Riteks that much. People have also been reporting a decline in the quality of Riteks. I use TY media and Maxell (made in Japan) for most of my DVD burning.
TANSTAAFL -
the burned dvd also plays fine on my computer and laptop. im really annoyed, does anyone have anymore suggestions? im sure some of you have had this problem, maybe its a problem with the dvd burning software, which is a good software besides nero 6?
Have you tried to play your burned DVD on another desktop player. Software players will play lots of stuff that desktop players will choke on.Originally Posted by Spetznaz24
As I understand the audio & video are in sync but the video plays in slow motion. Is that correct ? If yes, it could be a bitrate problem. Can you check the audio & video bitrates of the DVD you have created?
Hello, I have this problem also. I encode a video from my comp on to a DVD with AVI2DVD and it was laggy like that. I did another video from comp and it dident delay on this one. So I tryed another video and it had that really annoying delay in it also. I dont know how this happens but I think it might have to do with the source video having a lower bitrate. not really sure. Later.
Pioneer DVR-106D Burner with Compusa 2x dvd-r media
Burned DVD plays back with rolling / flipping screen
By thedaylights in forum Authoring (DVD)Replies: 3Last Post: 4th Nov 2009, 15:14 -
Burned DVD only plays in newer players
By rsherid in forum Authoring (DVD)Replies: 11Last Post: 16th Jan 2009, 05:02 -
Decrypted DVD9 plays fine from harddrive, not when burned to DVD+R DL
By ndaher in forum DVD RippingReplies: 4Last Post: 7th Sep 2007, 15:35 -
Burned DVD plays OK on standalone - not on PS2!?!
By offensekilla in forum Authoring (DVD)Replies: 5Last Post: 31st Jul 2007, 12:07 -
Mpeg Video Wizard DVD: Burned to DVD-R, Plays back with hiccups.
By Giovannini in forum Newbie / General discussionsReplies: 13Last Post: 27th May 2007, 06:54
