this is getting old. Xp SP2, divx 5.21, directx 9c. using VoBsub and virtual dub to add subtitles to a video i have. the pc shuts off mid way through. any help appreciated
Results 1 to 12 of 12
just to add, i have 1GB PC2700 and 3000+XP and when its converting the cpu usage is at 100%
If the CPU is running at 100% for that long, it's probably overheating.
Cheers, Jim
My DVDLab Guides -
Could also be bad ram or psu.
That was a hint...go back to SP1. Many have had unreasonable problems with SP2.
Cheers, Jim
My DVDLab Guides -
yeah..running Memtest-86 right now, and so far so good in the memory dept.
i slipstreamed my SP1 disc to SP2, so i might wipe the drive and load my SP1 disc tomorrow if nothing pans out tonight. thanks for your help.
Fellow Canuck. -
ok. went back to SP1, memory checks out fine..PSU was crap so i replaced it. virtualdub uses 100% of cpu when adding subtitles...pc shuts off halfway through conversion...any ideas?
oh yeah..temps are fine as well
47C during conversion -
ok fixed the shutdown, turns out with 3 dimm slots and 2 sticks of ram, asus recomends keeping them seperated by the empty slot. as for the freezing and 100% cpu usage, i read online to remove some unused codecs. would that work?
Conversion Problem
By Myrdivar in forum Video ConversionReplies: 3Last Post: 2nd Jun 2011, 04:44 -
Problem with conversion to DV
By SteveDM in forum ffmpegX general discussionReplies: 3Last Post: 25th Aug 2010, 08:54 -
conversion problem
By thomeski in forum Authoring (DVD)Replies: 2Last Post: 25th Apr 2010, 20:45 -
Help conversion problem!
By milney100 in forum Video ConversionReplies: 6Last Post: 11th Jun 2008, 05:51 -
video conversion problem
By eagle1 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jun 2008, 21:25
