I just installed the DIV3 codec because I received an error message in Virtual Dub Freeze.
Is this codec going to interfere or take precedence over a newer version and cause problems with other AVI's?
Should I (and how would I) revert back to a newer version and forego the convesion of this particular AVI?
TIA.
Originally Posted by celtic_druid
24bit Red, Green, Blue. DivX3 is internally YV12, as such the decoder should be able to serve YV12, YUY2 or RGB.
I'm sure that there would be a FAQ about colourspaces somewhere around here? -
"Couldn't locate decompressor for format 'DIV3' (Microsoft High-Speed MPEG-4 V3 Hack: DivX Low-Motion])
VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable." -
Make sure that DivX 3 is not set to disabled in the VFW decoder config.
Also if you installed the 2004.10.12 (think that is the one) version under win2k/XP then the VfW codec would not have installed correctly.
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 09:44 -
Audio doesn't play in AVI files, although AC3 codec IS installed
By DVantrease in forum Software PlayingReplies: 2Last Post: 16th Jan 2009, 17:57 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47 -
No Audio Output in AVI file where Codec is Installed
By yoshijam in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2008, 15:32 -
VD Complain Audio Codec Not Installed
By ks47 in forum Newbie / General discussionsReplies: 2Last Post: 19th Oct 2007, 10:46
