Hello,
I captured some DV movie from my Sony Camcorder with WinDV or Windows MovieMaker.
When I play back these movies with the Quicktime Player the quality is not so good (compared to Windows Media Player).
The picture has blocks and is not really sharp.
I like the Quicktime Player due to its abilities for navigation (frame by frame) therefore I would like to continue to use it.
Any ideas how to improve the play back quality of the Quicktime Player for these AVI/DV movies?
Thanks,
MM
quicktime player -- how we say it?
sucks so bad - it gets a value score of -5 even if free ..
it make even WMP look good ..
so stop using that spyware piece of crap and use a good player instead ..
did i mention that anything but QT files look like crap with it ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Second halves of my movies got bad quality
By el tiger in forum Authoring (DVD)Replies: 2Last Post: 12th May 2009, 22:24 -
Bad sound quality from avi's to DVD w/both Toast or XiliSoft DVD Creator?
By NoMoPackers in forum MacReplies: 7Last Post: 2nd Apr 2009, 04:57 -
How to playback file of XviD/DivX (AVI) into QuickTime player (Windows OS)?
By Leo99 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Aug 2008, 23:40 -
Problem with AVI playing on Quicktime player
By VidHunter in forum MacReplies: 9Last Post: 29th Mar 2008, 00:10 -
avi dvix, mpeg quicktime dvd quality question
By minmin2003 in forum Newbie / General discussionsReplies: 2Last Post: 26th Aug 2007, 13:16
