This doesn't seem that hard and i thought i would be able to do this on my own but i need help. I'm trying to convert a DVD movie to a 700mb Xvid avi file. I've tried using automatic programs like AutoGK and SimpleDivx but for some reason when i select the file size to fit on 1 cd (700mb) it comes out like only 300mb and not looking so great cause it's not using that extra 400mb that i want it to. I'm hoping there's an easy solution to this problem I just don't know.
When i try other more complicated methods like with DVDx it doesn't have a bitrate calculator so i've accidentally made the file too big so it won't fit on a cd.
Could someone help me out or point me to a guide that they know will help me convert a DVD to a 700mb xvid avi?
Hello,
You can try out dr divx. It's fairly easy to use. Just rip the vobs to the harddrive and point dr divx to them and set your paramaters.
https://www.videohelp.com/tools
You can find a videobitrate calulator in the tools section if your program doesn't have one.
I followed once this tutorial and it worked fine
http://www.ravenquest.net/heaven/xvid/xvid_howtos_menu0.htm
taboo
Converting Xvid AVI to DVD
By rocks911 in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 19:24 -
xvid to dvd converting help
By victoriabears in forum Video ConversionReplies: 12Last Post: 15th Nov 2010, 20:00 -
Converting .Xvid to DVD.... Please
By Galosat in forum Authoring (DVD)Replies: 2Last Post: 18th Sep 2007, 15:10 -
Converting from DVD to XVID
By morphjk in forum DVD RippingReplies: 11Last Post: 23rd Jul 2007, 16:33 -
Converting DVD to Xvid with a watermark?
By RushMaster in forum DVD RippingReplies: 1Last Post: 18th Jun 2007, 00:31
