Hi!
A friend of mine has a digital cam, model JVC gr-d33.
Is there a mini-DV adapter, so I can connect the mini-DV tape to the computer? Or do I MUST use the camera itself to do it?
Thanks in advace!![]()
Best regards,
Joelson. -
You mean Like a DV deck? Like a VCR? there are some they can cost anywhere from 400$ to 3000$.Take a look on ebay.
OK.
Anyway, this camera has only a s-video output. Does anybody know if there is a S-Video-Firewire cable, so I can output it to the computer?Best regards,
Joelson. -
You need to use the "Firewire", DV, IEEE-1394 connector and cable. It will be there someplace on the camera. Check the manual for location.Originally Posted by joelson
http://www.camcorderinfo.com/content/jvc-gr-d33-fi-camcorder-review.htm
http://www.videomaker.com/scripts/article.cfm?id=11159 -
i have the gr-d72 model. the setup is the same. on the left side where the controls are right under the s-video output is a spot for the usb cable and a spot that says DV. you need a cable with a 4-pin i.link connection on one end and a 6-pin ieee 1394 connection on the other. plug the appropriate end into your camera and the other to your computer and use something like windv or avio to capture the avi.
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 10:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 18:27 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18 -
mini jack adapter med to utganger
By jebinio in forum AudioReplies: 1Last Post: 13th Jul 2007, 17:58 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 03:11
