Hi everyone ,
I recently stumbled onto a website ( www.220giftcenter.com/ )
that sells dvdplayers which will allow you to play any dvd on any tv.
Meaning,that if you buy a dvd movie from England that is coded region 2 and is in the Pal format ,this dvd player i.e.;Yamaha dvd-slioo will
allow you to play it on your ntsc tv here in the U.S.
Apparently it has a video converter ( 12mb) inside that allows the conversion to take place.
I went to the Yamaha web site but they had no such player.HOWEVER,
I then went to the U.K yamaha websit and their it was.
Is this too good to be true??No more region hacking ,no more problem
between ntsc and pal ?
PLEASE,PLEASE,does anybody know anthing about this kind of product??
At the www.220giftcenter.com/ website they are selling this product for
$239.99 U.S.
P.S.I have an OLD dvdplayer Sony DVP-C600D showing an error code
E:26:05.No teckh support knows specifically what is causing the machine to show this code and then shut down and not play and it won't allow me to open it to get the disk inside.
Thank you for any help in this matter.
dvddiva
"If Life is a bowl of cherries,what am I doing in the pitts"
Buy this Player Philips 642 , Does what you want and also Plays Divx and Xvid files and only about 60 70$ Canadian.
yea lots do this -- nothing special..
and thats a rip off price"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks a lot !!!
Converting DVDs from Region 1 (NTSC) to Region 2 (PAL)
By Astronautilus in forum Authoring (DVD)Replies: 8Last Post: 10th Feb 2012, 04:35 -
Best mobo that has an ISA (yes ISA) slot?
By sdsumike619 in forum ComputerReplies: 15Last Post: 23rd Sep 2011, 23:42 -
Ntsc BluRay players play PAL(region-free) dvdr?
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Nov 2009, 18:48 -
Converting PAL Region 2 to NTSC region 1
By bevluvsrats in forum Video ConversionReplies: 10Last Post: 21st May 2008, 09:15 -
Will DVDplayer (OS 10.4.x) play a PAL dvd?
By rotuts in forum MacReplies: 4Last Post: 18th Jun 2007, 12:50
