Looking for opinions. I've only tried EZ CD Creator 5, and am about to un-install it. Any recommnedations on what should replace it? (I've got copies of Nero, and WinOnCD, not installed yet...)
Results 1 to 30 of 36
I've tried Win-on-CD, Nero, Acrapdetc and 1 or two others. ther best I found for me was NTI. It works great. They're at http://www.ntius.com
visit my China Railways page at;
http://www.azagel.com/crail.html
MIDI music on my site also. Have a nice day. -
@allenz
I checked NTI's website, but couldn't find any info if the CDMaker Software actually supports SVCD mode or WMF files, as Nero does. -
My personal choice is WinOnCD3.8PE, but I found somewhere 'Easy Creator DeLuxe Platinum 5.0' and hasn't tested that one yet..
If I have a bin/cue file, it doesn't matter which is best.. -
Can Nero and WinOnCD both be installed at the same time? I've heard about issues with Nero and EZ CD both being installed....
Nero and Direct CD cannot exist togather.
However, I have Never Burnt a succesful CD with nero.
Why???????
I uninstalled Direct CD. DOes EZ CD Creator have to die to? -
Why???????
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
YES, EZ CD Creator especially, has to be uninstalled before another burning software can work. -
I have been using couple burning programs: CDRWin, Adaptec Easy CD Creator and Nero.
I have to say that Nero is the best in my opinion. I can burn every kind of CDs with it with no problems (VCD, SVCD, Audio, Data, Games). It also converts audio to MP3 and AVI files to MPEG (never tried MPEG feature though).
I was using Nero 5.5.1.9 but now I updated to Nero 5.5.2.4 and this works better, specially the menu option which is great feature. I can add my own background menu pictures into the VCD or SVCD.
What about I-Author?
Is it any good? It is (or used to be) expensive. Is it available for purchase? It is not found among Enreach's products (www.enreach.com).
In the user guide on the left, it says that the created cd image can be burnt by Easy CD Creater, so they should be able to co-exist, right?
Thanks.
BeTa
This question "Which is the best burning software" (or similar questions) keeps reappearing. Would it be possible to put a table together summarising what each program can and can't do?
The programs :
1) Nero
2) Easy CD Creator
3) WinOnCD
4) Videopak
5) I-Author
6) CDRWin
7) NTI CD maker
8) VCDimage
9) ...plus others I'm sure
The questions
1) Video capability- VCD ?
- SVCD ?
- XVCD ?
- Menus ?
- Chapters ?
2) Photoalbum capability- Maximum number of photos ?
- Sound with photos ?
3) Other capabilities
4) Is there a demo available?
5) Is it available for download?
6) In which contries is it being sold?
7) How much does it cost in US$ ?
I'm sure this could be improved does anyone have any ideas?
<font size=-1>[ This Message was edited by: JohnT on 2001-07-17 11:08:06 ]</font> -
I like Nero and EZ Creator..
I use both, I only had problems with Nero durning install but sense install no problems.
I use Nero for vcd, svcd, mp3s, data, direct cd.
and EZ for mp3s, dirct cd, direct drive, data, system backup, blah blah blah...
any ways,
Nero = good for vcds, svcds.
Ez = good for everything else.. BUT I have never used the EZ for vcds and svcds and dont want too.
any ways,
I've been told you can't have both of these installed at the same time... -
They told you wrong!
I use (without any problems at all) Nero, EZ Creator, DirectCD (although I've uninstalled that one - got no use for it), WinOnCD, InstantDirect (great to write DVD's although I don't have a DVD-writer, but oke for CDR too), I-Author and VideoPack (VideoPack will leave soon too : the version in WinOnCD is much better !); all together on the same system in the same OS : WinME. -
@ Betamax
You're one of the lucky ones then. Normally using EZ CD Creator with another burning program has influence on certain drivers. I use WinME as well and once EZ CD Creator was installed (Nero was already installed) everything went wrong. Perhaps one has to install EZ CD Creator first, then Nero - I don't know. But installing and un-installing is so easy these days, I don't worry that much. -
Regardless of the burning software, it seems they all create file directories when burning a VCD. I have looked at the structure, and it seems the .dat file is in Mpegav directory. I was wondering how a DVD player knows to look there for the file (or if it does). There are no files in the root directory of the disk, so how can the player run the .dat file?
Just curious.... -
PS: Has anyone burned a VCD that plays in a DVD player? I'm beginning to think it can't be done....
I hope that was a rhetorical question <grin>
As for how the Player knows what to play - the information is in the firmware of each player (i.e. compare it to the operating system of your PC). Thats why certain DVD Players need firmware upgrades to be able to do this and that. -
aldus, I'll be more specific, has anyone burned a VCD that will play on a Sony S7000? This was their first DVD player, put out in '97, and it supposedly plays VCD's...
Playing VCD is different than playing CDR or CDRW. Perhaps the player is capable of playing commercially produced VCD's but cannot read a home baked CDR(w) produced VCD.
I have one of these players. You have to use CDRs not CDRWs in this player. I have used Imation and Verbatim with great success.
LDM, what software did you use to burn your VCD's for the S7000? Any tips or advice? -
On 2001-07-18 08:23:55, LDM wrote:
I have used EZCD and Nero. Better results with Nero.
Thanks. I have not had any luck so far with EZ CD, but it sounds like the media might be the main problem. Are the CD's you've burned silver? The TDK's I've been using are green. Did you burn yours at a lower speed as well?
Thanks... -
The Imations are silver. But the Verbatums are blue. I had limited luck with EZCD. Give Nero a try, worked better for me. You could try burning an audio CD first with your media if it plays that, the media is not the problem.
I've been successful with audio CD's with EZ CD, and the discs I'm using now. Someone told me that just because an audio cd worked, it didn't mean a VCD would. My Sony S7000 recognizes that these disks are VCD, but does not find any tracks... -
I have EZ CD Creator, Direct CD and Nero installed together. I had to install NERO FIRST and then install CD Creator and Direct CD. I am running Windows ME and I find that Nero is better for VCD and SVCD, as i have had a few MPEGS that EZ CD Creator said could not be used for VCD but Nero burned them fine. NERO gets my vote. If Nero is giving anyone trouble, you might want to turn Auto insert notification off if it isnt already
burning software
By hardy in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2011, 18:00 -
Best Burning Software
By bmoreravyns in forum Authoring (DVD)Replies: 32Last Post: 14th Oct 2008, 20:46 -
Best burning software???
By Eternal7331 in forum DVD RippingReplies: 8Last Post: 11th Oct 2007, 00:29 -
what burning software?
By dickdb in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Oct 2007, 17:48 -
burning software
By Cmonteith in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 19:07
