I just authored a project where all of the mpeg1 files were already DVD compliant (48KHz sampled audio), but yet svcd2dvd v2 rc5 insisted on resampling them, which wasted over an hour of time. Presently, RC5 fails to create the dvd files about half the time for unknown reasons. Taken together, for my future DVD's ( which can all be made from original DVD compliant mpeg1 files), RC5 will take more than twice as long as DVD Lab Pro to create my dvd's. Yes, it's fast for files NOT DVD compliant.
So bug reports are:
1. Needlessly resamples audio for files already compliant.
2. Fails to save settings properly, requiring saving a blank project as a work around.
Regards,
gealto2
1. If the audio is 48k it will not resample it. It will however need to remultiplex the mpg. It will not do anything if the file already has been remultiplex to DVD spec previously. (i.e if you reuse _S2D.mpg files or vobs)
2. Can you explian this further?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
So, if I rename mpeg1 files that are already DVD compliant to *_S2D.mpg, that will avoid the resampling?
I imported mpeg1 files that were made DVD compliant externally to SVCD2DVD, and were already multiplexed. The processing information indicated they were being resampled as if they were non-compliant, although the screen information agreed that they were compliant.
Some of my use for SVCD2DVD will be to reprocess video information on all my old VCD's that I created over the years to reduce storage size. Much of my use for it will be for newly authored material, where I am able to control the file properties.
I'm using ATI Multimedia Center with an ATI All In Wonder VE TV card to capture mpeg1 files in a variety of standards. I can capture in a fully DVD compatable, multiplexed mpeg1 file with 48 KHz audio directly. These are the files the SVCD2DVD pointlessly reconverted.
Regards,
Gealto2 -
Just because the audio is 48Khz doesn't mean that it has the structure the author a DVD. If a mpeg has Navigation packs it will not be processed further by SVCD2DVD. If the mpeg has 48KHz audio and no Nav Packs, SVCD2DVD will add the Nav Packs. No resampling will take place however.
Thanks for the clarification.
My confusion is how DVDlab Pro is now much faster in producing the DVD images (about 25% faster), and gives better looking results when used with compliant mpeg1 files.
I'm a little dissappointed with SVCD2DVD now.
cheers,
gealto2 -
Getting this error just after finishing ripping bin files -
Version:SVCD2DVD 2.0 RC5
Type: System.ArgumentException
Source: System.Windows.Forms
Message: Controls created on one thread cannot be parented to a control on a different thread.
InnerException:
StackTrace: at System.Windows.Forms.ControlCollection.Add(Control value)
at x3284ccece41ee22b.xddb8d1ea6c9958c7.x5aa416b67ec23 fff(x5d3356d9dffccb60 xc2a2a5b3a558ba7a)
at x3284ccece41ee22b.x210ff09a2516b1a7.xb3fbc61e17e47 28c()
at x3284ccece41ee22b.xe4d2667f3c3c2e1b.xc235541933b56 33b()
at x3284ccece41ee22b.xe4d2667f3c3c2e1b.xa167076587a68 80d()
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
any ideas ????
RC3 worked fine for me
back to v1.51 for now -
Crashuk2k1: I answered your other post here : https://www.videohelp.com/forum/viewtopic.php?p=1246515#1246515
Virtualdubmod errors?
By mrjust in forum Newbie / General discussionsReplies: 7Last Post: 14th Mar 2010, 19:01 -
Ripbot errors
By Benjy in forum Video ConversionReplies: 2Last Post: 21st Dec 2009, 08:03 -
New PC Burns With Errors
By NOIC in forum DVD RippingReplies: 22Last Post: 29th May 2009, 13:12 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 11:53
