Hi there.
I recently noticed that My Red Hot Chili Peppers: Live At Slane Castle DvD had a large scratch at the side and decided to make a back up of it.
I immediatly started shrink and loaded the disc, Now it reads to 97% then hits me with a data error, cannot read.
Now I did it again and activated the video preview, the mean menu, tracks and all round even is fine, Its the end credits that are causing the problem, that must be where the scratch it located.
DvD Shrink wouldnt continue.
I started up DvD Decrypter/ Mode ISO Read, began the process... again 97% error, cannot continue.
Now I dont really care for the end credits, I just dont want me use my original anymore, but i do watch this concert a LOT, so I really want a back up for my pleasure.
Can anyone think of anything that would help me here?
Im ripping my hair out.
Ive tried to copy the files to the hard drive multiple times and am having no luck whatsoever.
Thanks in advance for anyone who has any idea whatsoever.
-SyXx
Results 1 to 9 of 9
you could also use vobmerge, and make it one big mpeg2 file, and then cut out the bad part and reauthor
member since 1843 -
You could always try using some sort of rubbing compound to remove the scratch. Even if you don't get the whole thing, you may be able to get most of it.
Rip with Decrypter, goto settings, select 'do not read errors', it is under I/O TAB, if it does complete then goto Shrink to re-author, shrink and encode into an ISO file.
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
Major 'Codec' Problem
By mattstan in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2007, 16:18 -
Major Problem with DVD Xpress DX2
By AcidFMHQ in forum Capturing and VCRReplies: 0Last Post: 22nd Aug 2007, 07:02 -
Major Problem with AVI
By thepcpitstop in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 6th Jul 2007, 12:49 -
major problem
By Antitrust19 in forum ComputerReplies: 6Last Post: 28th May 2007, 09:30
