I used the following Guide
https://www.videohelp.com/forum/viewtopic.php?t=224833
to create a MPEG2 file from a VOB file
when I pull the MPEG2 file into Windows Media Encoder and Real Producer, they both claim that the file is invalid
but Windows Media Player and Real Player will play the MPEG2 file just fine
I'm trying to create a smaller file for streaming
Can someone shed some light on why this is happening?
Thanks.
Any (well any good at least) app that creates mpegs from VOBs (like TDA) don't "create" the mpegs - they are just unpacked out of its VOB envelope. Now, my tool par preferance for demuxing VOBs is ReJig - I suggest giving it a try. After all, TDA is mainly for authoring (the opposite if what you're trying to do).
/Mats -
That's mostly done by the authoring app - or else, it can be multiplexed back together using TMPGEnc (mpeg tools).
/Mats
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
"Non valid Key" in GUI for DVD Author
By Harry Cover in forum Authoring (DVD)Replies: 1Last Post: 11th Nov 2007, 15:35
