Hi...I was able to successfully burn my first VCD just a few minutes ago and I am sooooooooo happy! I have reached my first goal and now have to reach for the second. My ultimate goal is to make an SVCD. I am using windv, virtualdub, tmpeng and VCDeasy. I am using freeware versions of the software. I can't seem to raise the standard to SVCD. Am I doing something wrong or is this a limitation of the freeware?
Thanks!
Results 1 to 10 of 10
Thanks...I am using Windv to transfer the file from my Sony to the computer. I use virtualdub to do the editing, TMPGEnc to do the encoding and then VCDeasy to burn the CD. I did not know that about TMPGEnc. Are there limitations with VCDeasy also?
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Originally Posted by xinjingqiao"Art is making something out of nothing and selling it." - Frank Zappa
Originally Posted by ZippyP.
I think I may still have on older (free) version of VCDEasy. I can email it if the filesize isn't too large. Given it was freeware at the time, I'm guessing it shouldn't be classed as warez by offering it. Apologies if it is, and (of course) it won't be sent (sorry).There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
The older versions are available on the web if you search around.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks! I have the latest free version of VCDeasy. I will check the other websites to see about the cost of the other software. It seems to work very well with little trouble so I would like to keep it. The computer I am using is only a 2.4 ghz celeron so I like the idea of using several programs and not having to load 50 mb of software that works...some of the time..maybe most of the time but does not always work as it is supposed to. I had this problem with a Ulead program, version 7. I also felt that the program was too busy with so many things crammed into the screen.
If you are looking for a free solution I would suggest to try avidemux2(here look for avidemux and after that follow the Windows link for avidemux2). It makes absolutely compliant VCD, SVCD, DVD mpeg1,2 streams with mpeg2enc. It is slow like TMPGEnc. But the beauty is that the application is codecs independant - it has all built in.
How to make an AVI better quality (keeping output still as AVI)?
By Dogpoundz in forum Video ConversionReplies: 15Last Post: 22nd Sep 2011, 00:12 -
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Make SVCD from prepared directory
By Gimballon in forum Authoring (VCD/SVCD)Replies: 2Last Post: 18th Jun 2008, 07:35 -
How do I make an AVI from a Still
By WuTangDvD in forum Newbie / General discussionsReplies: 11Last Post: 27th Feb 2008, 11:41 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37
