Hello,
I'm really new to the art of making DVD and I have a question. I've been using WinDVD creator to make slideshow movies of my digital picture. I've made several movies with different themes. My problem is this... as far as I can tell WinDVD creator only allows me to burn one movie to a DVD. But i want to make a menu where i can choose several diffrent movies. Hopefully there is someone here that can help me with this issue...since i'm sure it can be done, i just don't know how.
Linn
There are guides that specifically adress that issue, just click on the guides section to your left, also do a forum search on your topic. You won't get much in the way of responses if your question has been thoroughly covered several tomes already.
The general answer is yes, you can put more than one movie on a single layer dvd, the more compressed the video file, the lower the quality. The only person that can judge whether a movie at say a resolution of 352x240 and a biit rate of 2000 is acceptable is you, because it is in the eye of the beholder. Nyah Levi
Software to get home movies off DVD and Burn DVDs
By Angel835 in forum Newbie / General discussionsReplies: 6Last Post: 30th Jul 2011, 22:28 -
DVD Flick Won't Burn whole Movie/movies
By armani_coke in forum Newbie / General discussionsReplies: 0Last Post: 17th Jun 2010, 14:07 -
HD Camcorder - Can you burn HD movies to DVD with the right software?
By xstein in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 13th Sep 2008, 01:27 -
Burn Already converted MPEG Movies To DVD
By killagoob in forum Newbie / General discussionsReplies: 1Last Post: 19th Apr 2008, 21:11 -
how to burn 2 main movies on one dvd, i have done it but only one plays.
By UmmAddan in forum Video ConversionReplies: 4Last Post: 28th May 2007, 09:54
