I was wondering how you might go about adding a still frame/artwork that will show up when the stop button is pushed ..... Some of the pressed DVDs do this ... was wondering if possible in DVD-Lab Pro?
for some reason i knew that question was gonna come up ...... im in the process of going thru my movies to find the ones that do it (cant remember off the top of my head which ones) Will post a few that do it shortly
Matrix Trilogy
Starship Troopers
Pirates of the Caribbean
Scooby Doo
When stop is pushed they display box art(front cover of dvd case insert).......Works both in my APEX 1165 & 1100 + my PS2 so im thinking its not just a dvd player extra but something on the disc (command list?) -
It's a "jump to" in DLP.
Set a "Return to last menu" then inside that box, put the image you want displayed, and set it's delay.
There's a tutorial on this on the DLP site.Cheers, Jim
My DVDLab Guides -
Originally Posted by reboot
Thank you .... i always thought that was cool the way that works .... thanks again for the information -
R1 version of hollow man does the same.
LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
You can also follow this guide and get the same results
https://www.videohelp.com/forum/viewtopic.php?t=235177&highlight=dvd+jacketThere is nothing illegal, until you get caught!
help with DVD Lab Pro
By medo_256 in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2010, 21:02 -
Help with DVD Lab Pro
By blacksheepdownunder in forum Authoring (DVD)Replies: 12Last Post: 31st Dec 2009, 23:01 -
DVD-LAB Pro 2
By Sanmaame in forum Video ConversionReplies: 4Last Post: 23rd Oct 2008, 04:42 -
DVD Lab Pro
By Flying Doctor in forum Authoring (DVD)Replies: 6Last Post: 16th Jun 2008, 09:00 -
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 07:53
