Are there any good methods of converting a dvd to divx/xvid in one step? I love for instance dvd2one when converting a dvd9 to dvd5, no hassle just input the video_ts folder and press start. What about conversion to avi?
Kal
Look at Gordian Knot and Auto Gordian Knot
I'm sure there are guides here. There are also guides on the DOOM9 WEBSITE as well.
AutoGK is probably your best bet. Not quite one-click, but so close even a bare beginner won't have problems. Just input the DVD folder, choose the output filename, soundtrack you want (usually selected automatically), select "Add Job" and "Start."
One thing about AutoGK, it adds a spyware called "DAE" to your PC which is very easy to remove... just go to Control Panel/Add Remove Programs right after installing AutoGK, and uninstall "DAE" then reboot. It's totally gone after this and AutoGK still works fine. Too many people complaining about this one and it's really no issue at all.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
