i looked around google & download.com for a time calculator.. i was unable to find anything decent..
basically i'm looking for a program that would allow me to add a bunch of times together, or even just 2.
here's an example:
41 minutes 25 seconds +
1 hour 23 minutes 18 seconds +
and then give a result, and allow me to add or subtract from the total.
i thought these programs would be plentiful, but i had no luck..
any suggestions?
Microsoft Excel will do that.
just type cells in the format HH:MM:SS and sum them together."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
no, like this. I used your first 3 times
notice the cell with the total is a function summing cells A1 through A3
okay, i've got all the times listed in the correct fashion.. what do i do to add them together?
find a cell and type
=SUM(XX:YY)
where XX is the first cell in the list and YY is the last
in my screenshot see how cell A5 has
"=SUM(A1:A3)" but displays "2:03:25""A beginning is the time for taking the most delicate care that the balances are correct."
Total video time calculator??
By shentheory in forum MacReplies: 3Last Post: 2nd Nov 2011, 17:01 -
What is the best Bitrate Calculator ?
By Simmons in forum Video ConversionReplies: 6Last Post: 15th Jan 2011, 08:08 -
Calculator Question
By tb582 in forum Video ConversionReplies: 14Last Post: 7th Feb 2009, 12:26 -
bitrate calculator
By pcb in forum Newbie / General discussionsReplies: 9Last Post: 1st May 2008, 11:34
