How can I shift the waveform back/forward for a period? for example, I want to shift the audio between 00:01:00:000 and 00:05:00:000 to a new position(e.g. shift forward 10 second), so it can start to play at 00:01:10:000 and end at 00:05:10:000. I cannot find a way to do it in wave editor. Is it possible to realize this function?
Thanks very much
you can also create an empty waveform of 10 seconds, and then cut and paste it to the beginning of the wave you want to offset.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Using Nero Wave editor, just select a 10 sec portion of your clip, Edit>copy it, and then paste at the beginning. With this portion still selected, if you then click on Volume on the menu and choose mute, it will give you a blank section.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Goldwave "Add Silence" IIRC (or "Insert silence" maybe?)
/Mats
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 13:50 -
Are Wav audio and PCM audio the same thing?
By yoda313 in forum AudioReplies: 2Last Post: 22nd Mar 2009, 16:46 -
what freeware editor lets you edit left and right portions of your wav
By Onceler2 in forum AudioReplies: 15Last Post: 11th Jan 2009, 09:46
