I just got a "sense key = medium error" trying to burn with Memorex 8x discs. I've had great luck with the 4x Memorex, but I've made four coasters trying to get the 8x discs to work. Other posts in this forum imply that this is probably due to bad media or the burner crapping out. I've successfully burned just a few days ago (4x dvd's), and I was just able to burn onto a dvd-rw (I'm out of 4x discs), so I'm guessing it's the latter. Has anybody had success/failures with the 8x memorex?
I'm on a 1ghz imac (dvr-105 burner) with OSX 10.3.8. Does this burner have problems with 8x discs? Could it be that I need a firmware upgrade? I know that there is some non-apple firmware floating around. Anyone have any experience with those? Any help would be appreciated.
-mekronk
Unless i am HORRIBLY mistaken, the DVR-105 is a 4x drive. To get above that you would have to :flash: it and that is always a risk
i would imagine they would work when burning 4x however. What brand are they? -
The DVR-105 is a 4x drive. I assumed that it would burn the 8x media but at the 4x speed. Is that wrong? It seems like the 4x media on the store shelves is quickly being replaced by the 8x dvd's, so maybe I need to try flashing my drive. Is it really that risky?
-mekronk -
Mostly flashing requires access to a PC. If you have it i would give it a try, but my motto is just get something better. Most drives that are set to a max have trouble with disks above and beyond thier "normal" range, and will usually only burn those faster disks really slow. 1x for example when you use a 8x disk in a 4x drive.
Most new drives you can get for REALLY cheap, plus the DVR-109 boasts a 16x burn with 6x DL support for under $80!
I have the DCVR-108 which is also an amazing price and mine burns at 12x dvd-/+r with no problems. -
I'll go you one better, master galactica:
http://www.newegg.com/app/viewproductdesc.asp?DEPA=0&description=27-129-160&CMP=BAC-de...T=DVR-109%20BG
I'm planning to move into one of these myself at home SOON.
suppliers for 2x media for the a-104 are DRYING up very fast!!!"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
My first post: connrccting a DVD to a comcast DVR to record from ther DVR
By retired_guy in forum Newbie / General discussionsReplies: 10Last Post: 24th Jul 2011, 18:54 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 07:20 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 12:23
