I know these questions will sound dumb to those much more veresed in these subjects, so I apologize in advance. Are all avi files the same? If they are not the same can they be mixed on the same dvd if your stand alone dvd player supports playing Divx and Xvid? Can you just burn them directly to dvd? What about mpeg1 files; can they be burned directly to vcd? Thanks in advance for your help. I am also looking at purchasing a Phillps 642 stand alone dvd player. What do you some of you think about it?
Hello,
https://www.videohelp.com/convert
Theres a good place to start.
AVI is a container and can be any codec.
I've read some divx players don't like xvid unless you add a header to the xvid though no personal experience with that.
If your mpeg 1 file is vcd ready than yes - read here for the specs:
https://www.videohelp.com/vcd
Plenty of reference guides in the HOW TO section on the left
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
