Using DVD stripper to split into two discs. I used the save project file option so I could come back at a later time and finish it. Now when I go to open the DVD stripper program I get a "Run-time error - CMruList component failure" and DVD stripper will not start. Anyone else have this error?
http://www.dvdrbase.com/showthread.php?t=37076
try that thread there, you may have saved the filename too long
. I know you are splitting the DVD but there are other blanking tools you can use now ranging from the free Vobblanker to DVDRemake PRO
Thanks MackemX, I deleted the folder in the registry per your instructions and everything works great now. I also finished spliting into two disks and both play excellent.
James -
thanks for the feedback and I'm pleased you got it to work, it's appreciated
. You should try looking at the other alternatives though as there's more programs you can use now that make the process much simpler
DVD Flick Run-Time Error 13
By amrcnbut in forum Video ConversionReplies: 2Last Post: 28th May 2011, 15:50 -
Avisynth batch scripter run-time error 380
By dude112 in forum Video ConversionReplies: 4Last Post: 13th Oct 2010, 12:13 -
DVDAuthorGui run-time error 75
By boborg in forum Authoring (DVD)Replies: 4Last Post: 16th Jan 2009, 14:37 -
Rebuilder Run-time error ‘52’
By coody in forum DVD RippingReplies: 2Last Post: 4th Jan 2008, 11:03
