The first DVD project made with full version of SVCD2DVD V2 RC5 was a success, the second one failed giving the following message, and no disk image was created.
Version:SVCD2DVD 2.0 RC5
Type: System.ArgumentOutOfRangeException
Source: mscorlib
Message: Specified argument was out of the range of valid values.
Parameter name: Not a valid Win32 FileTime.
InnerException:
StackTrace: at System.DateTime.FromFileTimeUtc(Int64 fileTime)
at System.DateTime.FromFileTime(Int64 fileTime)
at System.Timers.ElapsedEventArgs..ctor(Int32 low, Int32 high)
at System.Timers.Timer.TimerAPCCallback(IntPtr data, Int32 lowValue, Int32 highValue)
at System.Threading.WaitHandle.WaitOneNative(IntPtr waitHandle, UInt32 millisecondsTimeout, Boolean exitContext)
at System.Threading.WaitHandle.WaitOne()
at System.Timers.WaitableTimer.ListenerThread()
Regards,
Gealto2
Is that the whole of the errror text?
Ok. when does this error occur exactly? During processing or after the processing is finished?
The error occurs as the processing nears completion, right at the time the disc image should begin creation. If I reuse the *_SD2.mpg that should reduce the later processing time. These files are produced before the crash.
Regards,
gealto2 -
Im getting this error as bin files finish being extracted:
Type: System.ArgumentException
Source: System.Windows.Forms
Message: Controls created on one thread cannot be parented to a control on a different thread.
InnerException:
StackTrace: at System.Windows.Forms.ControlCollection.Add(Control value)
at x3284ccece41ee22b.xddb8d1ea6c9958c7.x5aa416b67ec23 fff(x5d3356d9dffccb60 xc2a2a5b3a558ba7a)
at x3284ccece41ee22b.x210ff09a2516b1a7.xb3fbc61e17e47 28c()
at x3284ccece41ee22b.xe4d2667f3c3c2e1b.xc235541933b56 33b()
at x3284ccece41ee22b.xe4d2667f3c3c2e1b.xa167076587a68 80d()
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae() -
This error is because you goto the menu window and then choose "Quick DVD". It will be fixed in the next release. Remember that the "Quick DVD" option does not produce a menu on your dvd.Originally Posted by Crashuk2k1SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
SVCD2DVD Error when encoding menu??
By gsmb in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 23rd Feb 2011, 14:44 -
System.NullReferenceException with SVCD2DVD 2.5
By Gripweed in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 13th Aug 2008, 14:27 -
Error on Startup SVCD2DVD 2.5
By jenevans33 in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 05:05 -
Error reports in SVCD2DVD
By deoldeprinter in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 5th Nov 2007, 22:03 -
svcd2dvd error urgent request
By dvds2u in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 10th May 2007, 10:22
