@FulciLives:
Mainconcept 1.4.2 has 2 settings:
The input capture setting and the output encoded setting.
In a way, the capture plug in frameserve to the encoder when you use that fuction. During the frameserving, the encoder can also resize.
When you do realtime mpeg 2 capture, set the input module to 768 x 576/480.
Then, encode to 720 x 576.
When you encode at a lower framesize, let say 704 x 576 or 352 x 576, then something wierd happens: A sort of "statering" at the bottom of the screen. This is a bug of the encoder, and I don't see anyone interest to fix it (it doesn't exist on mainconceptPVR a bad buggy program overall).
I never manage to eliminate totally that statering when MC output at 352 x 576. There is a kind of distortion always (mostly noticable on scrolling text).
But, when you grabb 768 x 576 and output at 720 x 576 with 2000min / 3800 average / 6000 max the picture look excellent. IMO looks exactly like what PVR 350 can produce at the same framesize and the same bitrate!
Of course this is my opinion. Others may have other kind of results to state.
I would never use mpeg 2 solutions for the convertions I'm interest to put on DVD. I use mpeg 2 solutions only for the things I want to do a quick and dirty convertion or the source is a satellite channel with bad compression (like the ones from UK's Sky Digital)
Results 31 to 38 of 38
La Linea by Osvaldo Cavandoli
Originally Posted by SatStorm
I didn't realize it worked that way!
Did I ever told you that you are fast on replying?
I always edit my posts for typos and stuff, and you always manage to reply in the meanwhile!
For a Zombie you are a fast one!La Linea by Osvaldo Cavandoli
I'm still trying to get Mainconcept mpeg encoder to capture with my PVR-250.
I open the program, select Tools, Capture, and then select the device (Hauppauge...) and it craps out with an error in captureengine.dll
Am I totally missing something?
On another note, the latest drivers from Hauppauge wouldn't allow GB-PVR to work, however, the latest from shpsvr, once installed using their convoluted method, DO work with GB-PVR.
MCE has never worked, except with my old cap card.
Any ideas? A reinstall maybe?Cheers, Jim
My DVDLab Guides -
Originally Posted by reboot
There is no reason to use Mainconcept MPEG encoder to capture. The only reason to use it to capture is when you have a capture card that does NOT do HARDWARE MPEG encoding on capture. An example would be the capture card you had but got rid of for the Hauppauge
Yeah, I knew that, but, up above, I could have sworn that Satstorm said something about the PVR-250 and Mainconcept...I'm probalby wrong agin
Edit: my spel chekr inst wrokinCheers, Jim
My DVDLab Guides -
I never said that you can use PVR 250 with mainconcept for capturing.
See? I told ya I was prolly wrongagain.
Age is showingCheers, Jim
My DVDLab Guides
Help Choosing Capture/Tuner Card...or Other wise
By drtalk in forum Capturing and VCRReplies: 2Last Post: 3rd Sep 2010, 17:46 -
How do capture cards get audio when using tuner
By GLE3 in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2010, 13:33 -
tv tuner/analog capture resolution problem
By cooldude859 in forum Capturing and VCRReplies: 4Last Post: 13th Dec 2007, 01:16 -
TV tuner with hardware MPEG encoding
By mb508 in forum Capturing and VCRReplies: 7Last Post: 19th Sep 2007, 07:52 -
Are all US tv tuner capture devices going to ATSC models??
By yoda313 in forum Capturing and VCRReplies: 6Last Post: 13th Jul 2007, 14:26
