Is it possible to take a one hour mini-dv video and do the following:
capture it,
encode it,
author it ,
burn it,
without losing so much of the file. For example when I use ulead dvd movie factory to do a all-in-one dvd I lose alot of the size of the original file. A 12GB file will be compressed to a 4GB file. I know this will fit better on a dvd but the quality is not as good as the mini-dv. Is it possible to compress alot less to get better quality?
I do not care if I have to put it on more than one dvd.
If so what tools do I need?
doogietim
Use a different encoder, and encode at a higher bitrate. Split it into as many disks as you like, generally at about 1 hour high quality per dvdr.
Cheers, Jim
My DVDLab Guides -
Try this link to get the most out of ulead moviefactory;
http://www.jonesgroup.net/media/id174.htm -
Also look at on-line manual on ulead site;
ftp://ftp.ulead.com/pub/Manual/DVDMovieFactory/3.0/dvdmf_standard_e.zip
or for disc creator version here;
ftp://ftp.ulead.com/pub/Manual/DVDMovieFactory/3.0/dvdmf_advanced_e.zip.
BTW, don't follow the guide above verbatum as it is for capturing already compliant files, but enabling the advanced encoding option allows you to tweak the settings in the encoder built into mf (based on mainconcept encoder) to hopefully improve your output quality.
Does a simple AVCHD authoring program exist like DVD programs?
By Killer3737 in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Sep 2011, 12:16 -
Simple DVD Authoring
By DeathStalker77 in forum Authoring (DVD)Replies: 22Last Post: 26th May 2010, 02:40 -
Simple VOB authoring solutions
By kippard in forum Authoring (DVD)Replies: 5Last Post: 22nd Jul 2008, 09:27 -
Again on Simple DVD authoring
By asadfx in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2007, 08:22 -
Authoring a simple DVD
By asadfx in forum Newbie / General discussionsReplies: 2Last Post: 21st Nov 2007, 16:54
