Hi guys.
For quite a while, I've been considering a switch to Linux; however, because I do a lot of work using CJK (Chinese, Japanese, and Korean) languages, and that happens to be one thing Micro$oft actually does well.
So, my question is, basically, do Linux IMEs exist for CJK languages? Also, do programs exist to read Chinese (both Simp. and Trad), Japanese, and Korean within Linux?
Thanks,
Ma Jie
(1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
(2)Philips 8631 @ BenQ1620 w/ B7U9 w/ MCSE speed patch
GET MCSE HERE
BenQ Ownz j00 -
If you don't get an answer here, ask your question at Http://www.linuxquestions.org
Short answer, yes.
Check out www.distrowatch.com . You can search by distro, country of origin, and/or langauge(s) supported.
Most do have Kanji input, though the translation is hardly ever 100% complete. So, some programs will either display native english, or completely screwed up fonts. -
I do know that KDE supports many different languages, I would assume that those are included. I think distrowatch is probably your best bet though for finding a distro suited for you. Personally I use Slackware 10.1 with the 2.4.xx kernel. www.slackware.com.Originally Posted by Ma_Jie
Revolution in computing - The New HP Touchsmart
By cplevel42 in forum Newbie / General discussionsReplies: 15Last Post: 10th Sep 2011, 02:50 -
Eye Opener: Cloud Computing Power Requirements
By ahhaa in forum ComputerReplies: 3Last Post: 31st Mar 2010, 07:16 -
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 20:27 -
Linux
By gooberguy in forum ComputerReplies: 3Last Post: 19th Jun 2008, 11:08 -
Nero Linux 3 Delivers Blu-ray and HD DVD Data Burning Support to Linux OS
By BJ_M in forum Latest Video NewsReplies: 0Last Post: 28th May 2007, 10:23
