is there a program that can recover a damaged/scratched disc.........i have a dvd with a scratch on it and it wont play properly is there a disc recovery program like the audio one called audigrabber or similar ????
Are you thinking of EAC (Exact Audio Copy) for CDs? Anyway, for DVDs, try ISOBuster. Use DVDDecrypter if it is a commercial DVD. You could polish out the scratch with toothpaste (white gritty kind) and your finger, then try ripping it with one of the above.
Good luck.Pull! Bang! Darn!
Clear inner plastic circle of discs (damaged)
By MattMVS7 in forum Newbie / General discussionsReplies: 7Last Post: 18th Sep 2011, 16:59 -
Wanted: Acer Aspire 2930z Recovery Discs - Drives & Windows
By Teac23 in forum ComputerReplies: 3Last Post: 12th Nov 2010, 18:30 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Damaged MPEG-4 File recovery
By bLAcKOuT. in forum Newbie / General discussionsReplies: 4Last Post: 11th May 2009, 15:25 -
Is there anyway to copy damaged DVD discs?
By Rockstar452 in forum Authoring (DVD)Replies: 9Last Post: 30th Nov 2007, 13:00
