    Sep 2003
    Tampa, FL
    I have a few video clips that are coded with DivX 5. Video is black, but audio is OK.
    Are there any utils to fix this issue? Gspot tells me that I have 3 compatible video and audio codecs; and the render test works as well.
    What am I missing?
    USA
    Try running it through VirtualDub Mod and see if it will display. If so, you may be able to do a direct stream copy and use that file. Or re-encode it to DIVX there.
  3. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    i had this problem the other day and it was driving me crazy
    turns out i had set my video card's TV out to be the primary display....
    D'oh!!
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
