I recently replaced my aging TV Wonder PCI with a Sapphire Theatrix. An odd problem I am having is with the audio on certain channels. On channel 3 and sometimes 4, the audio is plagued by static. Sometimes it is so bad that I can barely understand what people are saying on TV. The problem is not software related as it happens regardless of what program I am using.
To make a long story short, it seems to be coming in on the cable. Here's the deal: the cable comes out of the wall and goes into a 2-way splitter. From there one cable goes to the computer and the other goes to the VCR/TV. After some messing around with the cables, I found that I can stop the static if I unplug the cable going to the VCR. The static does not return if I plug the cable back in. However, if I unplug the cable, plug it back in, then switch to another channel on the computer and come back to channel 3, the static is back.
Could the problem be a weak signal and I lose too much going to both devices? Is there some feedback of some sort from the VCR? Would a better splitter (mine is very cheap and crappy) solve the problem, or do I need some sort of a filter to block feedback? Any other ideas?
Thanks for your help.
Results 1 to 1 of 1
Static image + audio track. Possible with VirtualDub?
By benquo in forum EditingReplies: 24Last Post: 19th Jul 2013, 09:07 -
Audio skew correction causing static in begining of audio.
By NextJinGamer in forum AudioReplies: 1Last Post: 3rd Sep 2008, 14:33 -
Static in FLV Audio in VirtualDub?
By RedPenguin in forum Video ConversionReplies: 0Last Post: 24th Jun 2008, 06:19 -
Static removal from captured audio
By Hal05154 in forum AudioReplies: 0Last Post: 8th Jun 2008, 09:51 -
VOB to mpeg: audio static
By thumperstrauss in forum AudioReplies: 1Last Post: 10th May 2008, 11:57
