Hi,
I have a Panasonic DMR-E55 and it won't play burned image files. I tried several different types of media (+R, and -R). I get a "cannot play" message from the DVD player. Any idea why and how to get around this?
Thanks in advance for your help.
Results 1 to 16 of 16
If you use good -R media (like MADE IN JAPAN type stuff, i.e. Taiyo Yuden or Maxell) then you should have no troubles.
It is either your media or the way you are burning etc.
Let me venture a guess here ... you are using NERO to burn your DVD discs? If so STOP THAT!!!
Use DVD Decrypter to burn instead.
If you need to make an ISO IMAGE file then use the classic version of ImgTools (must be the classic version!)
Thanks for the advice.
You are correct I have been using Nero to burn my DVD's. It has worked fine for SVCD's but not DVD's. I am using Sony DVD -R and +R which work fine in my player for SVCD's but not DVD's.
I'll try burning with DVD decrypter. What is the latest version of Decrypter?
Thanks again. -
If you need to use ImgTools then get the classic version (version 0.91.4) and the newest version of DVD Decrypter is version 3.5.2.0
- John "FulciLives" Coleman
P.S.
Post here if burning that way makes a difference."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
HI again,
DVD decrypter is asking me to "format" the DVD. Nero never asked me to do this. How do i format?
Thanks. -
It doesn't ask you to format if you are using a DVD-R disc.Originally Posted by Azucho98
I only use DVD-R discs.
Apparently you are using something else.
So I cannot help you there.
"DVD decrypter is asking me to "format" the DVD. Nero never asked me to do this. How do i format? "
Those are RW disks, no wonder they don't play on your panny. -
I used another disk and the format error went away. I think the first disk was damaged.
Anyway....I get the same message from my player "cannot play" with the sony DVD-R disk. Perhaps I should try another brand?? -
Try Taiyo Yuden DVD-R discs.Originally Posted by Azucho98
Any FUJI package of DVD-R discs that says, "MADE IN JAPAN" is Taiyo Yuden. You can also buy Taiyo Yuden on-line at RIMA.COM which is almost always cheaper per disc (but you must buy a minimuim of a 50-pack but this is only $25.00 plus shipping).
You can also buy Maxell DVD-R discs but again look for the packages that say "MADE IN JAPAN" although it is MUCH easier to find Maxell DVD-R packs that say this than it is to find FUJI DVD-R packs that say this.
Those two (Taiyo Yuden and Maxell MIJ) are generally regarded as the best DVD-R media around.
Thanks for the advice. I'll try differen't media and let you know how it turns out.
Thanks agian! -
Might be a good idea to fill out your computer specs especially what computer DVD burner you have.Originally Posted by Azucho98
My point about the media is this ... use the best there is thus eliminating media as a possible problem in this instance.
Hopefully that is the only problem here but if there is another issue you can at least rule out media being the problem by using top grade stuff.
P.S.
Also continue using ImgTools classic for creating ISO IMAGE files and DVD Decrypter for burning. Hard to go wrong (nearly impossible) with that combo. This way you are also eliminating the burning process from the possible causes of problems."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
I put my computer information into my profile. When you have a chance take a look and let me know if you see any possible issues there.Originally Posted by FulciLives
Thanks again for your time! -
I have a Panasonic DMR-E55, a fine machine BTW. I use all sorts of media, from the cheapest to the expensive, with no problems. I use either Tmpgenc DVD author or Nero 6.3.1.17. I suspect that its either the way you are burning, or even a problem with E55 itself...
dvd recorder topics:
https://www.videohelp.com/dvdrecorders
I use Accu disks on my Panny, they are pretty cheap now. -
I am starting to think my problem could be my DVD burner. I have a Sony DRU-530A with the 2.1C firmware.Originally Posted by mh2360
I see you are using a NEC DVD burner. The difference in DVD drives could be the difference....
While I am on the subject, what is the best DVD burner on the market today?
picture control on Panasonic dmr e55
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jan 2012, 17:41 -
How to set correc IR (black level in panasonic dmr e55 and es15)
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 13th Nov 2011, 10:42 -
panasonic dmr e85h no audio/won't record
By janeydoll in forum DVD & Blu-ray RecordersReplies: 2Last Post: 30th Mar 2011, 17:13 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 14:09 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 15:33
