HI,
I've wated about 10 disc trying to figure this problem out. I compile my DVD with DVDmaestro then I go to burn with NERO, Then when I click write, it begins to start the burn but then a box appears saying, "There has been a possible read error during operation, this may result in a defective write. Continue anyway?" These days I click no, but I have tried clicking yes and what happens is, it'll burn 75% or so, then fail. This is not the only way I've tried burning either. I've made an .img and tried burning with DVD Decrypter too, but the same thing happens. Anyone give me a hand with this, I've been at it a week!?
oh I forgot to mention, it has 6 episodes on it and 4 menus
thanks
What type or burner and what is the media code of the blanks your using?
My writer is an oldish one... Panasonic LF-D311 the media I'm using is a datawrite 8x disc. But they've always worked fine for me as has this process. I did try taking my episode menu out and then it burned ok, but without the episode menu. However, I need that. So I figure that this is a problem with either the assets or the structure, but I've re made the disc about ten times in maestro and re -encoded the assets, and I still get the same thing... However after this rebuilder of the disc, removing the menu doesn't seem to work anymore.
I'll take any suggestions/theories
DVD Architect Pro 5.2 error writing file?
By dabezt in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Aug 2011, 08:55 -
ShowBiz DVD 2 Error - Failure writing the disc
By smbcingu in forum Authoring (DVD)Replies: 4Last Post: 2nd Jan 2011, 17:34 -
Error in writing a YUV frame
By krao in forum Newbie / General discussionsReplies: 11Last Post: 1st Sep 2009, 11:47 -
DVD writing error
By nathy85 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 18:00 -
Error writing to media
By minepup in forum DVD & Blu-ray WritersReplies: 2Last Post: 21st Jul 2007, 08:28
