I have backed up hundreds of dvd's with very few problems, however i am now experiencing a weird kind of snag.
I am copying/backing up a few dvd's for my daughter to use in her room(gives me some peace when i want to watch the movie). my PC copies the files up until VTS 01 0.bup then just won't copy. I have tried 6 different films and they all stop at the same point.
However with the ones I burnt this morning it copies no problem???
Could this be due to the fact that the problem films were burnt with a different burner, ie my previous burner was 4 speed and my new one is an nec 16 speed dual layer.
Any help would be great as i'm pulling my hair out!
Results 1 to 12 of 12
Hello,
The type of burner doesn't matter. What program did you use??? Was the disc scratched??? Details are important.
First of all try different rippers. Dvd decrypter does a very good job at tackling the toughest discs.....
Hello
I used either nero or dvd shrink for these discs can't remember which for each film.
I have tried dvd decrypter but even this won't do it! Could the discs have deteriorated, I store them correctly and they are only a few months old.
I'm wondering if it could just be a problem with my pc? -
Hello,
EDITDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Hello
Can you explain your last post please (or am i just being dumb?) -
Are you labeling the DVD's?(ie adhesive paper)
If so don't,use a Sharpie type pen or use an inkjet printer.
The .BUP file might be corrupt,drag the VIDEO_TS folder to your desktop and delete all the .BUP files then right-click and send the .IFO files to My Documents.In My Documents rename every .IFO file with .BUP then drop in the VIDEO_TS folder.Open the files in DVDShrink to see if you get an error,if not burn away.
Good Luck -
Thanks for that but if I could drag the video ts folder to my desktop I would but because it won't drag the bup file i can't do it.
I do use labels and always have done using a proper applicator, although as of now i'm never going to use a label again.
Its not just the bup folder either as it won't drag any vts folder once it gets past vts 2?? -
Try this: spray a little WD-40 on the label, wait 5 minutes and peel off. Spray a little more and wipe the adhesive gunk off. Wash both sides with mild soap and dry with soft clean cloth.
Bet it rips for you then. Voice of experience.
Pull! Bang! Darn! -
You Sir are an abosolute star!!!
I followed your advice and have copied them all. I can't thank you enough the wd40 trick although very messy was a brilliant bit of info which everybody should know about.
Once again thank you.
Goodness gracious me!!!
You're quite welcome.
[EDIT] BTW, it was Moviegeek spotted your problem.
Pull! Bang! Darn! -
And for all the people out there that still think that putting a label on your DVD is OK...well here's another person that won't be doing that again!
"Art is making something out of nothing and selling it." - Frank Zappa -
Here is an e-mail I received recently regarding wd-40, now add removing dvd labels.
They say there are only two supplies needed to get through life successfully - WD-40 and Duct Tape. If it moves and it shouldn't use Duct Tape. If it doesn't move and it should use WD-40. And now here is a list of WD-40 USES. Amazing. R
(Thank you, friend, who sent this list to me. R)
WD-40
I thought that you might like to know more about this well-known
product. When you read the "shower door" part, try it. It's the first
thing that has ever cleaned that spotty shower door. If yours is
plastic, it works just as well as glass. It's a miracle! Then try it on
your stovetop...Viola! It's now shinier than it's ever been. You'll be
amazed.
The product began from a search for a rust preventative solvent and
degreaser to protect missile parts. WD-40 was created in 1953 by three
technicians at the San Diego Rocket Chemical Company. Its name comes
from the project that was to find a "water displacement" compound. They
were successful with the fortieth formulation, thus WD-40. The Corvair
Company bought it in bulk to protect their Atlas missile parts. The
workers were so pleased with the product, they began smuggling (also
known as "shrinkage" or "stealing") it out to use at home. The
executives decided there might be a consumer market for it and put it in
aerosol cans. The rest, as they say, is history.
It is a carefully guarded recipe known only to four people. Only one of
them is the "brew master." There are about 2.5 million gallons of the
stuff manufactured each year. It gets it's distinctive smell from a
fragrance that is added to the brew. Ken East (one of the original
founders) says there is nothing in WD-40 that would hurt you.
Here are some of the uses:
Protects silver from tarnishing.
Cleans and lubricates guitar strings.
Gives floors that 'just-waxed' sheen without making it slippery.
Keeps flies off cows.
Restores and cleans chalkboards.
Removes lipstick stains.
Loosens stubborn zippers.
Untangles jewelry chains.
Removes stains from stainless steel sinks.
Removes dirt and grime from the barbecue grill.
Keeps ceramic/terra cotta garden pots from oxidizing.
Removes tomato stains from clothing.
Keeps glass shower doors free of water spots.
Camouflages scratches in ceramic and marble floors.
Keeps scissors working smoothly.
Lubricates noisy door hinges on vehicles and doors in homes.
Gives a children's play gym slide a shine for a super fast slide.
Lubricates gear shift and mower deck lever for ease of handling on
riding mowers.
Rids rocking chairs and swings of squeaky noises.
Lubricates tracks in sticking home windows and makes them easier to
open.
Spraying an umbrella stem makes it easier to open and close.
Restores and cleans padded leather dashboards in vehicles, as well as
vinyl bumpers.
Restores and cleans roof racks on vehicles.
Lubricates and stops squeaks in electric fans.
Lubricates wheel sprockets on tricycles, wagons and bicycles for easy
handling.
Lubricates fan belts on washers and dryers and keeps them running
smoothly.
Keeps rust from forming on saws and saw blades, and other tools.
Removes splattered grease on stove.
Keeps bathroom mirror from fogging.
Lubricates prosthetic limbs.
Keeps pigeons off the balcony. (they hate the smell)
Removes all traces of duct tape.
I have even heard of folks spraying it on their arms, hands, and knees
to relieve arthritis pain.
Florida's favorite use was "cleans and removes love bugs from grills and
bumpers.
The favorite use in the State of New York--WD-40 protects the Statue of
Liberty from the elements.
WD-40 attracts fish. Spray a LITTLE on live bait or lures and you will
be catching the big one in no time. Also it's a lot cheaper than the
chemical attractants that are made for just that purpose. Keep in mind
though, using some chemical laced baits or lures for fishing are not
allowed in some states.
Use it for fire ant bites. It takes the sting away immediately, and
stops the itch.
WD-40 is great for removing crayon from walls. Spray on the mark and
wipe with a clean rag.
Also, if you've discovered that your teenage daughter has washed and
dried a tube of lipstick with a load of laundry, saturate the lipstick
spots with WD-40 and re-wash. Presto! Lipstick is gone!
If you sprayed WD-40 on the distributor cap, it would displace the
moisture and allow the car to start.
WD-40, long known for its ability to remove left-over tape mung (sticky
label tape), is also a lovely perfume and air freshener! Sprayed
liberally on every hinge in the house, it leaves that distinctive clean
fresh scent for up to two days!
Seriously though, it removes black scuff marks from the kitchen floor!
Use WD-40 for those nasty tar and scuff marks on flooring. It doesn't
seem to harm the finish and you won't have to scrub nearly as hard to
get them off. Just remember to open some windows if you have a lot of
marks.
Bug guts will eat away the finish on your car if not removed quickly!
Use WD-40!
The applications appear to be endless
Problem copying DVDs to hard drive (previously copied from videos)
By avz10 in forum RestorationReplies: 4Last Post: 2nd Mar 2010, 23:54 -
copying a Windows XP hard drive
By joecass in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 11:00 -
Copying and converting files to external hard drive
By soxenme in forum Newbie / General discussionsReplies: 4Last Post: 25th Feb 2009, 18:16 -
Copying Your Hard Drive
By wulf109 in forum ComputerReplies: 6Last Post: 9th Feb 2008, 00:13 -
I want to reauthor DVDs without copying to the hard drive first.
By Big C in forum DVD RippingReplies: 2Last Post: 24th Jul 2007, 20:54
