  1. Is it possible for me to add a menu to a DVD I have already created? I no longer have the source files, and just put them on the DVD as chapters 1-9.
    But now I'd like to add a menu onto the front to allow me to select chapters 1-9 without skipping through the rest.
    Many thanks for any help
    Matt
    Dec 2004
    Canada
    youd have to burn a whole new one you cant add to a dvdr that you already burned. But just use the one you made and burn another disc, itll cost ya 50 cents.
  3. Yeah.. I gathered I would have to burn a new disk. So it is possible then?
    What program is best to make easy menus?
  4. DVDLab will import the .vob's directly off your current DVD, and allow you to reauthor with any menus you want.
    Cheers, Jim
    My DVDLab Guides
  5. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
  6. Thanks - I'll give that a go
