  1. OK, got this working fine eventually, but when decoding a DTS stream into 6 .wav files, the channels get mixed up. Happens with AC3 too.
    I have to find a definite test dts or ac3 stream that pins down which channel is which, but I was wondering has anyone else seen this problem?
    Cheers!!!
    Be part of the process, not just subject to the outcome.......
  2. Member daphy's Avatar
    Europe
    you need some test files for mapping questions? stay tuned I will add some of those files on 'needfulthings' with the next update 8)
    bye Daphy
  3. Hey Daphy, I have found some test material and have the following info for you. The channels are mapped in the following way.
    input - front left -- output - front left
    input - centre -- output - front right
    input - front right -- output - centre
    input - rear left-- output - lfe
    input - rear right -- output - rear left
    input - lfe -- output - rear right
    This happens in exactly the same way with ac3 and dts.
    I have written a simple dos batch file to rename the output files, but I thought I'd bring this to peoples attention!!
    Cheers!
    Bb
  4. Member daphy's Avatar
    Europe
    yesterday I´ve uploaded a little app called BeSweet Mux Wizzard(by LigH) -> you will find there some further informations about mapping in diffrent (target) formats
