Results 1 to 20 of 20
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.Want my help? Ask here! (not via PM!)
very strange as it works fine for me
how about this image I've linked above or this link below? It's nothing amazing just a guy sticking stuff in himself to create records
http://www.humanpincushion.com/component/option,com_gallery/Itemid,44/ -
Hello,
Nope - neither link works.......
isn't that strange? I haven't a clue why but maybe a pipe is down somewhere along the line for you guys as I'm not imagining it and the site works fine for me
huge amount of dns issues today on the web -- see my connection thread in 'computers'
link...Originally Posted by BJ_M
https://www.videohelp.com/forum/viewtopic.php?t=260552 -
i just switched to treewalk DNS and that helped a lot (works for all all broadband)
http://ntcanuck.com/"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Worked for me.
This is what you should see:
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
You may want to try using a proxy server. Check out http://www.publicproxyservers.com/index.html - the've got hundreds of them. To use in Explorer go to Tools -> Internet Options -> Connections -> Lan Settings and check ON proxy server then enter the IP and the port.Originally Posted by yoda313
treewalk DNS worked ...
i dont have problems now
see above for link"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hello,Originally Posted by SquirrelDip
No luck - I tried two of the US ones and no go - no net at all.....
Oh well - so I can't see the website - big whoop....
Kevin
Thanks for the suggestion though
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Have you tried BJ_M's suggestion?Originally Posted by yoda313
Hello,
Haven't gotten around to it yet... no biggie..
isn't that one way to bypass IP blocking?Originally Posted by SquirrelDip
people aren't missing much, just some sad git sticking things in himself to break world records
