I have captured an avi from d/v via Win DV which plays fine through WMP. When I try to encode it using Tmpgenc or Ulead it has horizontal interacing which is really noticable during any motion on screen. I checked the avi file with GSpot and under the Stream Type and A/V interleave box it says Type:Open DMV avi IMRR:n.s. I/L not supported. Is this the root of my problem.
I tried encoding it and burnt it to DVD but the lines are still visible.
Any ideas folk?
Adepizza
Can't get rid of interlace lines
By MacFast in forum Newbie / General discussionsReplies: 1Last Post: 31st Aug 2011, 22:41 -
Seeing interlace lines after exporting from After Effects
By theguy1991 in forum EditingReplies: 14Last Post: 15th Jun 2010, 15:39 -
VirtualDub can't find an audio compressor while GSpot can for my avi. Help!
By yosarian in forum AudioReplies: 13Last Post: 2nd Dec 2008, 09:01 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 12:07 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 11:26
