im trying to connect an ibm laptop (model t23) to a 42 plasma screen(philips).
and i just cant get it working.
my problem is the refresh rate, i need to lower the refresh rate to 50hz
but i dont have the option to do that with the current drivers installed on
the laptop,the lowest i can get right now is 60hz
i even disabled the display adapter in the device manager to get the
lowest settings for it.
the plasma works fine when i connect other laptops to it and set
the refresh rate on the laptop to 50hz.
any idea?
maybe a progam that will let me lower the refresh rate to what i need?
anything you can think of?
thanks
HELL AINT A BAD PLACE TO BE
there was a program I had before that allowed you to customize your settings. I'm not sure what it was or for which card it was for either?
I'm sure it was something like Powerstrip or something
:edit: it is powerstrip and here is a link I just found
http://entechtaiwan.net/util/ps.shtm -
doesnt work, i cant set a lower refresh rate then 60hz
but thanks anyway.HELL AINT A BAD PLACE TO BE -
plasma should work just fine with 60hz refresh also
won't the plasma have settings to change the refresh?
what model philips is it and which mode are you using e.g. VGA/SVGA etc -
i cant remember the model of the plasma right now, but i talked to
the the service guys and they say it will only work with VGA and
50hz refresh rate.
the vga is not a problem, but the refresh rate is.
i did try it with other laptops and it works fine with 50hz ,
as soon as i make it 60hz it doesnt work.
so the service guys are right about that.
anything ealse you can think of?HELL AINT A BAD PLACE TO BE
Connecting LG Plasma via HDMI with PC - flicker problems
By TjS2011 in forum DVB / IPTVReplies: 19Last Post: 6th Dec 2011, 13:05 -
Connecting Toshiba laptop to 42 inch insignia plasma
By Brianarkansas in forum Newbie / General discussionsReplies: 1Last Post: 9th Mar 2011, 00:46 -
Looking to hook my laptop up to my 42 plasma
By marionr26 in forum Software PlayingReplies: 12Last Post: 26th Nov 2009, 17:35 -
Connecting XBOX 360 with 720p Plasma HDTV: So HDMI or Component Av Cable??
By jajabinks92 in forum DVB / IPTVReplies: 2Last Post: 29th Nov 2008, 09:16 -
connecting my laptop to my plasma and lcd
By krisyrfc in forum Newbie / General discussionsReplies: 2Last Post: 19th Jan 2008, 14:23
