Hi there - i'm fairly new to this scene
Trying to convert Divx 576x304 @ 23.976fps to 480x576 PAL @ 25fps
Using LSX or Tmpgenc, i get a very slight stutter - once every second - on fast motion or scene panning.
I've changed bitrate and a few other things like frameserving it to lsx, but i just cant get rid of the stuttering.
What am i doing wrong?
Cheers
Results 1 to 10 of 10
you are making a 25 frame movie from a 24 frame source that is a big no no cant get a pal from ntsc you wil get a missing frame every 25 frames that is the jerkyness just makle a 24 frame ntsc svcd.
I think i might have it
Virtualdub - de mux audio/video.
convert frame rate, using single pass quality Divx.
Use LSX to change to Mpeg2 SVCD
Mux with Tmpgenc
Seems to be nice and smooth - could someone confirm if this is ok?
too difficult, make it more simple:
1. extract sound using vdub (save wav)
2. change length of sound (adjust to 25 fps pal from 23.976 ntsc film means you have to speed up the sound a little, approx. 95.90%) for example with cool edit
3. start tmpgenc, select 'do not frame rate conversion', use original divx as video source, resized wav as audio source, generate
the speed change will not be noticed by the average viewer
tell me if you get it to work, got a little spreadsheet here to make it easier to calculate the numbers, remember that audio length might not match video length!
oops - deleted the Wav, only left with the Mpg encoded audio
any tools which either stretch/shrink mpg audio, or allow mpg -> wav (all i can find is mp3 to wav)
just found out cool edit messes sometimes with divx mp3 encoded files after you extract them fromt the avi file... acoustica does the job properly...
Slight prblem with noise.
By Jimbo1 in forum Video ConversionReplies: 1Last Post: 25th Jun 2011, 09:57 -
Slight Hauppauge HD PVR Issue
By octaneflame in forum Capturing and VCRReplies: 4Last Post: 10th Feb 2011, 17:46 -
Slight problem with GOM Player
By jonghyunchung in forum Software PlayingReplies: 1Last Post: 22nd Oct 2008, 03:04 -
Is there a jerkiness (motion detection?) setting in CCE?
By robrosen in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 17:42 -
Bad NTSC to PAL converstion - jerkiness. How to fix?
By PTRACER in forum Video ConversionReplies: 34Last Post: 11th Sep 2007, 18:00
