  1. Is it possible to integrate, lets say, a 2 mins song in a motion menu of 15 sec loop?
    I tried with TEMPGenc but it seems not possible, I have to make the background motion duration equal to the song.
    Now I am messing with DVDLAB pro, but it seems to be that way too.
    Any work around?
    thx
  2. Do you want the song to be 15 seconds, or the menu to be 2 minutes?
    Either way, Dvdlab Pro can do it.
    Cheers, Jim
    My DVDLab Guides
  3. the loop motion sequences are 15secs while the song is 2mins.
    But all I found is the 15sec of loops reset the entire song and menu.
    I just want to be able to loop the motion thumbnail to loop indefinitly for 15sec without the song be restarted.
  4. Banned
    Oct 2003
    Americas
    Motion menu is a rerendered mpeg file. Complete with audio that is why audio and video have to be the same length. You can have a 2 min. audio looped under a static menu not a motion one. That would require playing mpeg and audio independently. Not possible.
  5. Create your 15 second video. Join it to itself to get 30 seconds. Join that to itself to get 1 minute, then join once more to get your 2 minutes. Load it into dvdlab, and add your 2 minute audio.
    Cheers, Jim
    My DVDLab Guides
  6. Thanks proxxy, that was very well explain. I now understand why most DVD menus sucks . Yes, I never been a big fan of DVD menus.
