I have a Toshiba notebook which, according to user's manual, has a shared headphone jack/SPDIF audio out. Since the manual does not provide any other information about this, I take it to mean that I can get digital S/PDIF output from my Toshiba notebook and route it to my home theater amp. Doing this would be great because instead of stereo I could, I'm assuming, get the full 5.1 surround sound when watching movies. Now my question is how do I properly connect my notebook to my A/V receiver via this shared headphone jack/digital S/PDIF audio output? Do I need any special cable to do this and, if so, what kind? I am using PowerDVD 6 Deluxe as my DVD player and there is a S/PDIF audio out option in audio preferences menu. Do I need to change any other audio settings anywhere else in my system?
Any advice is very much appreciated.
cheapest way is to pick up the 3.5mm to 2 rca outs and plug one of the rca outs to the spdif connection on your amp. the only settings i think u need to mess with is make sure to click the box that says digital out only in your sound settings
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
Thanks for the suggestion. I did as instructed but, unfortunately, I am getting no sound on my amp. I made sure to check 'digital output on for all devices' in my notebook audio device console, and to set S/PDIF output on PowerDVD 6 Deluxe. Does it matter if the 3.5mm is stereo, or mono (I tried both with the same result). What else is there for me to try? Are there any other options to disable/enable for my notebook? The cable is fine because I'm using the same one to get digital audio output from my DVD player and it works without any problems (to connect my notebook, I have used the same cable with mono/stereo 3.5mm adapter on one end).
i dont know. i never looked too far into it. maybe a google search
Tv with no headphone jack AND rca audio outputs
By gordes04 in forum DVB / IPTVReplies: 27Last Post: 23rd Jun 2013, 21:39 -
Stereo Out to headphone jack (3.5mm)?
By therock003 in forum AudioReplies: 34Last Post: 17th Feb 2012, 00:47 -
Any ideas on why audio through headphone jack stutters on MacBook?
By ryangarfield in forum ComputerReplies: 2Last Post: 30th Mar 2010, 22:07 -
Headphone jack extenders?
By Nintendo Fan in forum Off topicReplies: 5Last Post: 5th Jan 2010, 11:25 -
Audio/Video jack - is this a headphone jack?
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2009, 16:10
