    Sep 2003
    USA, MN
    I have intalled regmon, from sysinternals.com, and i was disapointed to see that there is not an option to let it run in the backround. Can someone tell me if there is a way i can make it autorun and then minamize to the tool bar, in the way a program like AVG does. TIA
    G.
  2. Member Soopafresh's Avatar
    Jan 2004
    regmon puts a lot of strain on your system, and even makes it liable to crash if you run it for too long. Besides, 30 seconds of capture gives you a thousand lines of calls to seek through.
    What do you want to accomplish by doing this ?
    Sep 2003
    USA, MN
    I only have it logging when a program writes to the registry, since this is all I want to know about. It doesn't log every time the registry is accessed.
  4. google "run as a service"
    Originally Posted by jagabo
  5. Member Abbadon's Avatar
    Dec 2003
    Caribbean Sea
    I don't think you will be able to accomplish this in Windows, in linux is very common, but in Windows only TSR programs can run in the background.
    No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
  6. Member Soopafresh's Avatar
    Jan 2004
    Aha....check out THIS page.
    http://www.sysinternals.com/ntw2k/info/regboot.shtml
    I'll mention it again, Regmon can be a strain on a system. If video playback on that machine starts stuttering out of the blue, you can be very sure it's coming from an app recording every call to your registry to a text file.
    Otherwise, THIS bit of freeware will minimize any app you want to the system tray.
    http://www.snapfiles.com/get/trayminimizer.html
    Sep 2003
    USA, MN
    alright thanks for the warning I'll have to see how it goes. I might only open it when I install new programs to monitor the changes.
